Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Spoolmate 30A
    Jul 2006
    28
    Default Spoolmate 30A
    I have a Miller Spoolmate 30A on my 251. I was pushing it out of the garage and the harness for the 30A got caught under the front caster wheel. It mashed & broke some of the wires . What I have to do is find a suitable connecter to do fix my screw up. I looked on Ebay and all's I found was connecters with 10 & 20 amp ratings , Does anyone have any ideas? Thanks.
    Mark
    Nov 2009
    western mass
    208
    the 10 pin connector? id imagine you could get it on miller4less. look up the manual on miller site and get the part #
    Nov 2003
    3,426
    Quote Originally Posted by oleblu72 View Post
    Mark
    Quote Originally Posted by cayager View Post
    I agree...
    If you want just the connector I believe this is the correct one..but doublecheck to be sure
    ..confirm that it is the right one before ordering
    190294 [1/PK] CONN,CIRC MS/CPC 10PIN SIZE 18 PLUG PANEL PUSHIN
    http://miller4less.com/product_info....ducts_id=38922
    if you want the entire control cable with connector this is probably the one
    204605 [1/PK] CABLE,CONTROL 30 FT
    http://miller4less.com/advanced_sear...17&search.y=10
    Here is the link to the manual
    http://www.millerwelds.com/om/o1213ah_mil.pdf
    BTW... 30A is the model name it has NOTHING to do with the Amperage rating...
    the Spoolmatic 30A is rated at 200Amps 100% duty cycle..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jul 2006
    28
    Thanks for the reply Cayager. I'm looking to splice into the harness with a male female connecter. I think I remember counting 5 wires, my concern is the amp rating on the connecters. I tried finding one at McMasters & carr with no luck but I'm gonna try it again I sure they would have one, thanks again.
    Mark
    The gauge of wire determines size and type of connector required.
    Nov 2003
    3,426
    Quote Originally Posted by kize View Post
    You are Barking up the WRONG tree...
    in this case
    This is a 10 pin control connector
    My Blue Stuff:
    8,104
    Amps? 20 -30 amp. Are you guys serious, this unit uses less than "1" amp
    The amphenol connector shell is a 10 pin 18 series male. There are 2 of the 10 pin inserts for this unit, best to just buy both, even I get confused on the 2
    Nov 2003
    3,426
    That's what I have been trying to tell them..
    why don't you sell him a set..??
    My Blue Stuff:
    in this case
    Barking up a wrong tree ?? I don't get your comment. I DO understand simple ohms law when it concerns wire gauge, connectors and splicing techniques. Whether it is control wire or 0 gauge.
    Nov 2003
    3,426
    Miller 10 pin
    The damaged connector just needs to be replaced with the same...
    My Blue Stuff:
