Results 1 to 10 of 10
    Feb 2013
    Canada
    112
    Default spoolmate 100 series
    just my impression on the gun
    -cheap quality!!!
    havent tried it yet but ......
    there is not 300$ worth plastic on that thats for sure!!
    but i guess for the job you gonna do with that thing ...better then nothing!!!!
    what you guys think?
    3,964
    Love em with my tip conversion of course. I also have a Westinghouse gun that i haven't used in years since i got my spool mate...Bob
    Dec 2012
    Front Royal, Va
    64
    I have used mine a dozen times and have had zero problems. I may call on the services of Bob to help me out with the tip conversion one day. I think i remember it being said that the end where the tips screw in gets hot and distorts along with the tips. Not sure. I have not run really long beads at one time, maybe 6 to 8 inches at a time. Go for it........
    HH 210MVP
    Spoolrunner 100
    Powercraft AC buzz box
    Lotas LTP5000D plasma
    Victor Oxy/Acet
    30 ton press
    A few brand name tools
    Lots of no name tools
    A wife to worry me
    and 4 dogs to supervise me
    Feb 2013
    Canada
    112
    i've got to say..
    -Pretty impressive!
    thats pretty amazing what equipments are capable nowadays....
    i did not fab up all day long withthe gun , but weld up a little square frame 1-1/4 x1-1/4x1/4 thick....
    did a great job!!!!!
    not to say.... my dynasty is unbeatable ... but not comparable either!!!
    if youguys look for a cool , capable little unit
    the millermatic 211 is a great machine
    and spool gun for it??? does a great jobtoo!
    havent tried stainless yet with the spoolgun..
    pretty sure it shouldnt be a prob!!!!
    "love it"
    Phil
    3,964
    Quote Originally Posted by Rhinox View Post
    "love it"
    Phil
    Here is a tip to remember when using SS or steel wire in the spool gun. The drive roll groove will wear so keep a spare drive roll or have 2 sets to switch out between aluminum and steel. Because after some steel it won't feed aluminum wire at all. Learned the hard way...Bob
    Feb 2013
    Canada
    112
    got 3 sets of drive rolls:
    -stainless
    -steel
    -aluminum
    i dont like mixing drive rolls for different materials!!
    gives you also a better purity in materials,
    do this with the bigger spool as well!
    Phil
    Wa
    661
    What gas will you use for the stainless?
    Feb 2013
    Canada
    112
    depending on utility
    -but usually tri-mix(Helium/argon/co2)
    if not really critical i will use the c25 i mostly use for steel
    "really depend on application"
    best way is tri-mix for stainless
    Feb 2013
    Canada
    112
    on mig -
    i use 100%argon for Tig on anything...
    Wa
    661
    Ok that's what I figured. Seems every time ss mig gets brought up, it quickly gets dismissed due to the cost and availability (lack) of tri mix. Do you have any pictures of work you have done with tri mix?
