Results 1 to 5 of 5
Hybrid View
    Mar 2014
    1
    Default TB 302 with wire feeder troubles
    Hey experts! I just got a 22a 24v wire feeder to hook up to my TB 302, but I can't figure out why it won't strike an arc, I think I may be missing a piece but am unsure..Can someone correct me?
    Oct 2007
    Cave Creek Az
    1,050
    Maybe you could tell us how you have it wired.
    Oct 2004
    Edmonton, Alberta
    8,197
    Plug the control cable in to the 302, turn your machine to remote CV, hook your pos cable onto the feeder drive, ground off your machine to the work piece and with the wire feed torch weld away, with gas or without depending on the application.
    I don't think you hooked up the pos cable to the feeder, something about being a magic feeder
    Nov 2009
    western mass
    208
    not to add to your post but also (if i remember correctly)switch the lead to the constant voltage lug on the machine. machine has a lug for constant current and constant voltage. right? unless newer machines dont do that.
    Oct 2004
    Edmonton, Alberta
    8,197
    True too, connect the pos off the CV post to the drive on the feeder.
