Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
    Apr 2012
    Western Kentucky
    118
    Default Bobcat 250 starting question
    This is the first Bobcat I've owned. Right after initial start it runs fast then after a few seconds it finally idles down. Never thought running cold engines wide open when they're cold was good for them. Is there anyway to adjust that out to allow a proper slow speed warm up?
    I guess the fact that they've been running for thousands of hours without problems settles the argument, but it just goes against what I've been taught about running cold air cooled engines hard right after initial start.
    Syncrowave 200
    Millermatic 252
    Spoolmatic 30A aluminum gun
    Miller Spectrum 625 X-Treme
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Two big fire extinguishers
    "I'm a slow walker, but I never walk backwards" - Abraham Lincoln
    northern NJ
    1,841
    I agree. I cringe when starting mine in the winter but that's how they are.
    MM250
    RCCS-14
    My Trailblazer does the same thing. I bought it new and it has done this since day one. Sort of like cars with a carburetor the butterfly stays closed until the engine warms up.
    Apr 2012
    Western Pa.
    220
    I'm the same!! Makes me cringe every time I start mine. I never rev a motor up till has good oil pressure and cyl. temp is up. That's basic engine 101. And if I would have reved a cold engine up as a kid a would have got slapped up side the head, & well deserved. I hate to start my Big 40 Diesel cold.
    Agreed they do last but how much longer and less repairs would u have if we're set up correct.
    I always run high quality oil and good additive such as Lucas or equivalent to keep damage at Min. Still makes me cringe every start.
    Oklahoma
    703
    Quote Originally Posted by Gobysky View Post
    I was taught the same as you. However, with age, experience, and education, I have learned this is the best way to start these engines.
    Let the howling begin.
    Griff
    P.S.
    Take Cruizer's advice and switch your oil to Castrol Syntec 5w50
    Nov 2012
    Northern Arizona
    475
    Quote Originally Posted by gnforge:318384
    Are you talking fuel or oil additive? If it is fuel them Lucas is not worth much. Stanadyne or optilube is goof fuel additive for diesels.
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
    Apr 2012
    Western Kentucky
    118
    Quote Originally Posted by griff01 View Post
    Griff
    P.S.
    I have the gas engine. Was that 5w50 meant for the gas or the diesel?
    Syncrowave 200
    Millermatic 252
    Maxstar 150 S
    Miller Bobcat 250
    Sketchup 8 Pro
    Oklahoma
    703
    I know he recommends the 5w50 for the gas engines but I am not sure about the diesels.
    Griff
    Apr 2012
    Western Pa.
    220
    Elvis: I was talking oil.
    I also agree, like stanadyne, better than Lucas and fppf etc. for fuel.
    Nov 2012
    Northern Arizona
    475
    Gnforge,
    Sounds good. There seem to be a lot of people that assume that a big company that makes a fuel additive must make it well. Lucas, amsoil and the like don't make a good diesel fuel additive. Only a couple that are worth anything.
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
