Results 1 to 3 of 3
    Aug 2014
    7
    Default maxstar 150 will not tig
    150 STH will spark on tig impuse. It will stick weld. It will not turn on output on any setting. I reset factory settings. Has little use over four years.
    Aug 2009
    Ankeny, Iowa
    45
    Quote Originally Posted by JoeBarth View Post
    Are you using the Remote and is it plugged ALL the way in? Darn things are too small to see and then that locking ring...
    Do you have the leads switched around so the torch is Negative and ground Positive?
    Can you hear the gas solenoid kick in when you switch the remote on or use the local control and touch the tungsten to the work?
    Miller MultiMate 200 MIG/ Stick/TIG
    Retired
    Journeyman Refrigeration Pipefitter
    Master Electrician
    Amateur Home shop Machinist & Welder
    Jan 2011
    6
    The fact that the unit still Stick welds is a good sign since that means the power components are still good. Have you tried the lift TIG setting? Have you checked your work clamp and cable to make sure it is making good contact?
    Are you using the remote control? If so, could it be bad i.e. could the remote be set at zero current.
