Results 1 to 10 of 16
    Feb 2013
    Canada
    103
    Default Dynasty 200dx and millermatic 211 wiring in the garage
    i have a dynasty 200dx that i use onsite once in a while but i alsouse it in the garage where i got a twist lock 230v30amp receptacle on the wall and 30amp breaker!
    the Dynasty runs awesome on that!
    now what if i decide to use the millermatic 211? can i just make a pigtail on the welder to match the wall receptacle? is 230v 30a alright to use the millermatic 211?
    or must i change everything on the wall and breaker.......
    Nov 2003
    3,431
    Just make an adaptor pigtail...
    guys that do a lot of onsite work generally have several pigtails that adapt from 6-50 to various range and dryer plugs..
    you can never be sure what you have to plug in to when you get someplace...
    so yes adapter pigtails are a common solution....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Wa
    624
    I have 4 or 5 adapter pigtails I use all the time on job sites.
    Feb 2013
    Canada
    103
    I knew that the Dynasty you could,wasnt sure about the millermatic 211..
    Feb 2013
    Canada
    103
    thanks...
    Nov 2003
    3,431
    Thumbs up
    Quote Originally Posted by Rhinox View Post
    They are both in the same ballpark..
    The Millermatic 211 draws 230 V, 25 A, 60 Hz, Single-Phase
    The Dynasty 200DX draws 230 V, 28 A, 60 Hz, Single-Phase
    My Blue Stuff:
    Dec 2013
    383
    On Millers literature, welder amperage seems low to me. Am I stuck in the twentieth century, or are the numbers adjusted down for duty factor? My thinking is the perennial problem so many at home welders face is small wiring to the garage. In mild cases this can be addressed with welders equipped with "auto line" style automatic voltage adaptation. In less extreme situations more current in a supply line means more heat produced, and more voltage loss. As many welders can run on 200 volts, voltage loss isn't always debilitating. Voltage loss means heat! heat produced in 2 minutes can often cool while a 20% duty cycle welder cools.
    IT IS STILL ESSENTIAL TO CALCULATE ALL COMPONENTS OF A WELDER SUPPLY AND CAREFULLY INSTALL OR CHECK. A BAD CONNECTION MEANS A FIRE USUALLY IN A LOCATION YOU WON'T KNOW ABOUT UNTIL IT'S TOO LATE.
    Nov 2003
    3,431
    Smile
    Quote Originally Posted by Willie B View Post
    Willie
    the numbers seem right to me....got them from the literature and manuals...
    remember.. both machines are inverters so they are going to draw considerably less power than the transformer machines we are used to..
    it does go to show how much more efficient the inverters are... and power factor considerations on the transformer machines that we don't need to worry about on an inverter..
    Here is a video that gives a lot of good general info on home garage welding.. (fair amount of sales pitch ... but a lot of good info as well)
    Starring.. Andy & John...
    Welding in your Home Garage
    http://www.youtube.com/watch?v=TdSdTtwN4i0
    about a half hour..
    My Blue Stuff:
    Feb 2013
    Canada
    103
    got the millermatic 211 plugged in!!
    work like a champ!
    -tell me if i did some not right!
    bought an extension cord 25' with 2 ends on it
    -6-50r and the other end was 6-50p
    -removed the 6-50p and replaced it with a 6-30p
    twistlock to match the wall !!!
    the wall , is 230v30amp as well the breaker
    plugged it and tried it... worked very well!!
    what you think????
    any danger??
    2,914
    work like a champ!
    what you think????
    any danger??
    yer good to go.
