Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
  1. #31
    Hi, I"m probably off topic a little bit. But I was wondering how you did such a neat an tidy job cutting the plate for the three point hitch frames?
    Is that done with a plasma cutter? Thanks Joe.
  2. #32
    May 2010
    Central CA
    781
    Default Jet
    Quote Originally Posted by RedBarnNate View Post
    Here is what we are currently building at our shop. We have complete 1 & it is being used currently, and are just finishing up 2 more. We will most likely be building 10 more. The customer wanted a hitch that was bulkier & stronger than a locally sourced cheap alternative. He uses them on compact CAT 1 tractors that pull fruit bin trailers for cherry harvest.
    An operator can more easily load/unload/hook up to trailers running the hitch off 3 point. Also, this places the pivot point of the trailer "further back" from the tractor, allowing for tighter turns without binding & tire rub.
    The builder is grinding welded surfaces to a "v" prior to welding. He is making 2 passes with 1/8" 6013 on our bobcat 250.
    Nat,
    Try 7018 jet on those welds, it will smooth them up real nice.
    6013 will run smooth with a little more heat.
    Your welds look cold around the toes.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
