    Corunna Ont, Canada
    455
    Default Bobcat 225G Plus
    Hey Jeff, I picked up a older bobcat to play with, it spose to run but not weld.
    So I had a quick look at it so far and found the fuel pump broke, so I have to fix that first and then get a run check in.
    Any good place to start looking for a problem???????
    Or is there a service manual to show test points?
    S/N KE724329
    Thx Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    226
    I had one of those welders . If it won't weld or make 120v I would start at the main fuses that was a weak spot on mine. If it makes 120v but won't weld these guys will help you. There's a op manual on miller site.
    Nov 2003
    3,690
    Smile
    Here is the manual that is correct for your serial number..
    http://www.millerwelds.com/om/o403a_mil.pdf
    AND...
    Here is the Service manual for your Onan P216 engine..
    http://www.cumminsonan.com/www/pdf/manuals/965-0762.pdf
    Gotta make it run first...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Corunna Ont, Canada
    455
    AND...
    Thx for the motor manual, did not have that one.....
    the regular owners manual don't really tell you a whole lot.... kinda need a service/tech manual.
    Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    226
    The op manual should show all the fuses I would start there and then look at the slip rings.
    8,334
    remove the top cover, you'll see the fuses right away
    Aug 2008
    Orange, TX
    1,217
    Once you get it running, if it produces auxiliary power but just won't weld, it's not a failed field current fuse F1.
    Check to see if it has weld output in CV mode. If no output in CC mode but output in CV mode, there is a connection between stator output lead #72 and reactor AC-Z input that has been known to fail resulting in no CC output but still have CV output.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Corunna Ont, Canada
    455
    Quote Originally Posted by duaneb55 View Post
    Will do sounds like a good spot to have a look, fuel pump should be in tomorrow and run checks on friday night or Sat.
    Thx Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Corunna Ont, Canada
    455
    Default Ok it's running
    Ok I have it running, it's not at full power yet, but a little tune up should help that.
    No power no where.
    What voltage should I have coming from excitition and going back into the rotor after going through the bridge rect.?
    Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
