    Aug 2004
    Milan Michigan
    1,894
    Default New 3/4" Impact gun 1560 Ft Lbs of torq.
    I have been working on alot more big trucks now that I have a bigger facility which requires a bigger impact than my 1/2" will do.
    I was looking at the Ingersorrand 3/4" drive that kicks out a whopping 1350 ftlbs of torque.
    But a friend of mine told me about the one made by Proto which has 1560 FT. Lbs. Mod # J175WP. ____________________________________ $ 352.87
    1,928
    Man that sounds like a great deal. No more struggling with your 1/2" gun & breaker bars with pipe extensions.
    Apr 2013
    metro Detroit
    95
    I work on tractor trailers every day. To get that kind of torque you will need to run it on a 1/2"air line
    Dec 2004
    Maryland
    135
    Default Impact Gun
    If your in the market for one ToolTopia has good prices.
    Aug 2004
    Milan Michigan
    1,894
    Along with the impact I bought 1/2" hose, 3/4" drive deep well socket set up to 1-7/8" and the big fittings.
    Aug 2004
    Milan Michigan
    1,894
    Up date on the price, They called me back to say they had the wrong price so it went from $ 352.87 to $ 435.64
    Fyi u will probably need 12-15 cfm compressor and at least a 30 gallon tank along with the1/2 inch feed
    Aug 2004
    Milan Michigan
    1,894
    I have a 80 gallon tank and approximately 23 cfm at 175 psi, I borrowed a friends 1" impact for this job, still waiting for mine to arrive.
    We mounted a Prentice crane on the log truck that we have been working on, there are eight 1-1/4" bolts that hold it on, The impact was as my daughters would say ( Amazing ) I tried to get a little extra torque on them with a 24" adjustable wrench and a 3' pipe over the handle, I couldn't budge it.
    I'm use to 1/2" impacts, this was a big upgrade.
    4,507
    You do spray threads with weasel pee before running them on? The Proto is still a good deal, I paid 200 more for my IR 20 yrs ago.
