Results 1 to 3 of 3
    Feb 2013
    16
    Default Suitcase 12-VS with WCC no wire feed adjustment
    I have sent the feeder in for repair.
    Curious if anyone else has had problems with the WCC suitcase?
    We are considering adding another set up like this but are now hesitant considering how few hours we got out of the feeder before the break down.
    Kelly
    8,021
    Were the dip switches behind the panel set correctly, these units are extremely reliable, actually the best on the market. 90% of the time its the guys draging the units by the gun. If the trigger terminals short out to the internal conduit, the same problem will occur
    Feb 2013
    16
    Dip switches were never changed, front panel never removed.
    Machine worked flawless for about 1 month.
    Could you explain what you mean by internal conduit?
    i.e. weld current passing through the trigger circuit?
    I know that some of the welders are working around of some large parts.
    It would not surprise me that they could end up pulling the suitcase with the gun.
    We have the feeder hooked to a XMT450. It is a beefy setup.
    Kelly
