    Default Blue Star 185 Stator Removal
    I need to remove the stator on a Blue Star 185 to clean out a dirt dobber nest. What comes next after taking the 4 long bolts out from the endplate? It looks like I need to remove the center bolt that goes into the rotor shaft so that the bearing can come off with the endplate, but not certain if that bolt is left-hand or right-hand threaded and the best way to get it out...Thanks for your help. Also, is there a service manual available that would have these procedures documented?
    Sep 2009
    Canada
    194
    What engine is in that welder?
    Has the motor lost spark?
    Any small engine I have ever worked on has the stator under the flywheel. This the flywheel has to be removed first.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Dec 2010
    Andover, Ohio
    155
    Welcome to the forum Charles76901.
    8,281
    The rotor needs to be pushed off the engine, there are threads in the shaft that I think are 3/8" can't remember, so get yourself some redirod and a couple nuts
    Aug 2008
    Orange, TX
    1,216
    Charlie, no need to remove the rotor or its center bolt to get the stator off on the Blue Star 185. Just remove the endbell cover, pull the 4 bolts holding the stator housing to the engine adapter plate, remove the brushes and holder assembly, pry the endbell off the rotor bearing and then slide the stator housing off over the rotor.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
Tags for this Thread
