Results 1 to 8 of 8
    Default Forney Inverter help needed
    Long story short. My dad let me try out his little inverter welder and I pushed it harder than should. It is a Forney AT-100 inverter stick/ TIG unit. I was trying it out with 3/32 7018 rod maxed out. About 3" of weld total. I then waited 5 minutes and ran 3" of 6013 when it turned off. Is it true Forney slapped their name on the Harbor Freight equivalent ? I can't get it to run again. It also has a constant on fan that will not run. Any info would be great. I just don't want to tell him his poor little welder was burnt up by me. Oddly enough the thing had great penetration on prepped and beveled 1/4" box steel
    Nov 2003
    3,635
    You may have cooked the thermal overload switch...
    I believe that USMCPOP has one of those little Chinese Forneys...
    maybe he could shed some light on your problem
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Apr 2010
    304
    I never had a Forney AT-100. My son had a little Harbor Freight inverter but sold it. I believe Forney had trouble with those welders. A lot of them showed up on eBay really cheap when they were discontinued.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    Nov 2003
    3,635
    Quote Originally Posted by USMCPOP View Post
    Sorry Pop
    Thought you had one of them..
    My Blue Stuff:
    Apr 2010
    304
    I had a TA Dragster 85 I got for $50. then flipped it and got the TA 161STL. Gave that to my son, the welder.
    Miller stuff:
    Dialarc 250 (1974)
    I appreciate getting back to me about that. Are there any wiring diagrams out there for the HF models?
    Nov 2003
    3,635
    Quote Originally Posted by Texas113 View Post
    Did find a link to Forney customer service
    https://www.forneyind.com/customer_service/
    Hopefully they could help you...
    My Blue Stuff:
    4,477
    I bought one for sport to see if a 100$ welder worked,,, yes and no. It is a 3/32 6011 unit period. Its not efficient enough to run a 3/32 lo hi. Not worth messing with a fix. For another 100 or so someone,,, green maybe, makes one a lot better.
