Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Nov 2012
    Northern Arizona
    538
    Here is something that came up locally. Might be something to consider. Might be too big for your current phase converter, i don't know. If you want me to check it out send me a pm.
    http://tucson.en.craigslist.org/tls/4349774204.html
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
  2. #22
    Feb 2013
    Southwestern WV
    96
    I can't get the link to work.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
    Acer Ultima "Bridgeport Mill"
    340hp Quincy and 400 gallon of air
    Other doodads and a stoker coal stove
  3. #23
    Nov 2012
    Northern Arizona
    538
    Quote Originally Posted by sledsports View Post
    Are you on a phone? I find that links rarely work when I am on my phone. Things like photobucket and such. Perhaps this is the same problem.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
  4. #24
    Feb 2013
    Southwestern WV
    96
    Default a little update
    Sorry its been so long since a follow up but the results on hooking up compressed med air to the plazma was astounding. I used Harris nitrogen two stage regulator and swapped out the nipple to fit the air cylinder. Used a 5/16 push lock hose with JIC fittings. I noticed zero pressure drop on the work side while cutting (had a buddy watch the work side of the gauge). The down fall to this consumption. Cylinder started full at 2600 and fell to 2300 in about 10 mins worth of cutting. I'm sure I could have conserved some but was kinda in a hurry. Its worth doing in my opinion. Consumables should last a lot longer.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
  5. #25
    Nov 2003
    3,436
    VERY COOL..!!!
    Great to know it worked out for you...
    and Thank You for reporting it back...
    that follow up will be helpful for others...
    Could you break down what the costs were..??
    My Blue Stuff:
    Dynasty 350DX Tigrunner
  6. #26
    Feb 2013
    Southwestern WV
    96
    The med air was cheap (free ;-) about 3 bucks for the Jic fittings, $15 dollars for the nipple (CGA-346), Im gonna guess 70-90 bucks for the reg- Harris 447-200-CR Pipeline. (already had it and I'm sure a good oxy reg would work). Its a single stage, sorry thought it was dual in my follow up. Had some left over push lock female jic fittings from a previous job with about 5 foot of hose so that was another free bee. So if I was guessing if you had to buy it all you'd be in the 150-200 dollar range. Just a rough estimate.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
  7. #27
    Nov 2003
    3,436
    Smile
    Thanks..!!....
    My Blue Stuff:
  8. #28
    May 2010
    Central CA
    784
    Med air thing is good for portable work also, but not every day.
    I use a small air compressor little jobs. With a full tank it ran my big plasma for short cuts.
    As I write this my new Champion Air Compressor (Aug.2013) is in the repair shop with a blown head gasket.
    Now when I have a big job I plug in my 302 Air Pak and fill all the booster tanks and run till the pressure is to low then Air Pak it back up.
    Sometimes a small back up air compressor is a good thing.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
