Results 11 to 20 of 28
    Mar 2011
    st-eustache qc.canada
    239
    your contactor and wire frying has probably been caused by that defective unloader valve, as it tried to start loaded. Some time also combined with a defective check-valve at the tank entrance ( also seen parts of the head valve plates stuck in check valve...) Don't tell us it has no fuses or breaker Ha!
    Mar 2011
    239
    HN 80 if you get your hand on a formula to calculate cfm at different psi and psi at different cfm or whatever...I'm interested
    Nov 2003
    3,511
    Quote Originally Posted by snowbird View Post
    OK... here ya go...
    http://www.engineeringtoolbox.com/co...ume-d_843.html
    http://www.engineeringtoolbox.com/fr...ir-d_1190.html
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Feb 2013
    Southwestern WV
    96
    Well you hit the nail on the head. Lol. Yes its breakered but its over killed like everything else I do.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
    Acer Ultima "Bridgeport Mill"
    340hp Quincy and 400 gallon of air
    Other doodads and a stoker coal stove
    Feb 2013
    Southwestern WV
    96
    I can see that you guys have your act together but I don't. I shoulda gathered up more information than I have before I start gouging out questions. Lol. I'll pick up a cylinder and some fittings and see if I can round up more info and get back with you guys.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
    Cave Creek Az
    1,048
    Oxy reg won't work, wrong nipple, may not give enough CFH. I did it with nitrogen years ago, used a high pressure Fischer reg that I used.
    How many horse compressor? Should have a centrifugal unloaded. If that is broke, just add a pressure switch with an unloaded on it. If it is 7.5hp or less, just buy a single phase motor and be done with it. Starters are about 50 bucks on eBay.
    Nov 2003
    3,511
    Quote Originally Posted by walker View Post
    Breathing air regulators use a "348" CGA nipple
    Oxygen regulators use a "540" CGA nipple
    http://www.ohiomedical.com/UserFiles...der%20Data.pdf
    My Blue Stuff:
    Aug 2012
    Hermiston Oregon
    278
    Default ppl)pkojjvp! mamp
    Q oow dr
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Apr 2006
    TAXACHUSSETTS
    1,502
    Why not just use a portaband?Or some .045 slice wheels on a angle grinder they make them for aluminum cutting ive used them work pretty well.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Lake of the Ozarks MO
    3,593
    Nitrogen is the correct gas anyways.
    I vote repair the Quincy. Dang good compressors IMO
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
