Results 1 to 3 of 3
    Feb 2014
    Default need info on AEA200 LE
    Hello to all, I took a Miller AEA200LE in on a job I did for a neighbor. It has a ONAN driver. Numbers on the welder are;
    SN: HE750786
    200 Amp AC Welder Generator
    Numbers on the engine are:
    CCK AMS /2237G
    SN: 174 747127
    I want to replace the faceplate on the welder as it has faded quite a bit.
    The engine was very hard to turn as it had some water in both cylinders. I am goin to pull both pistons and re-ring it while I got it down. Also, got to replace one intake valve.
    Anybody know if faceplate still available from Miller?
    Where to find parts for the Onan?
    Thanks for any help.
    Oct 2008
    6
    Default Try here
    http://www.lincolncontrolplates.com/...control_plates
    If you get one let me know if there any good or not thinking abot replacing mine.
    Sammy
    Apr 2012
    Western Pa.
    335
    I couldn't find the correct one for my 1988 Big 40 Diesel.
    My LWS stopped by and called Miller wile we were talking and Miller said they had a new one on stock. I ordered it but hasn't came in yet.
    I'll let u know if it's correct when comes in.
    May give miller a call, I was surprised they had one that old. Time will tell if it's correct.
    Greg
