Results 11 to 14 of 14
    Feb 2014
    10
    someone anyone ?
    Aug 2008
    Orange, TX
    1,216
    In addition to checking the limit switch LS1 you've already looked at, for max only output in CV mode, the book says to also check:
    1) Control Relay CR2
    2) Rectifier SR2
    3) Control board PC1 and its connections.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Feb 2014
    10
    Quote Originally Posted by duaneb55 View Post
    2) Rectifier SR2
    Thank you sir I have ordered CR2 relay and SR2 rectifier...
    I hope one of them fix it. I could not find PC1 control board but it looks like it will be very expensive will let everyone know how it turns out.
    Thank you
    Default SR2 rectifier
    I am having the same problem as j96simmons had with his shopmaster 300. After reading these post I checked the control relay CR2 and it is burnt, after testing, I would like to replace the SR2 rectifier but there is no name or numbers on it, can anyone tell me the correct rectifier to buy for this machine (amp and volt rating). Thanks
