Results 1 to 7 of 7
    Feb 2014
    3
    Default New syncrowave 210 weld critque
    Picked up a syncrowave 210 and figured i would give tig a go to see how it worked. Got a couple of pics. Just looking for some suggestions to get my skills up. All welds are lap joints on 1/8" aluminum @ 130amps with 4043. 2% ceriated 3/32" tungsten. Thanks
    Dec 2010
    Andover, Ohio
    155
    Welcome to the forum rday78.
    Wa
    643
    Overall they look pretty decent. It seems you may be having a bit of a hard time keeping steady. Make sure you are very comfortable, relaxed, and make sure the entire length of the bead stays comfortable for you to reach. I do mock runs of a bead so I can make sure the torch cable doesn't get bound on something mid weld, or me filler rod hits something. Just keep practicing at it, looks like your on the right teach.
    Feb 2014
    3
    Thanks... im a bit shaky by nature but ill keep at it. On the fillet welds i have a hard time directing the arc straight into the joint... it bounces from vertical plate to horizontal. Guess a bit more practice is in order
    Nov 2003
    3,622
    Quote Originally Posted by rday78 View Post
    Really good start
    All you need is learn to brace/steady your torch hand
    more practice and to develop your rythm...
    you may laugh but a metronome to give you a regular time spacing for your dabs of filler in the puddle may help you to get that going...
    I know... sounds goofy but that even beat may help
    Dab & Move Dab & Move.....
    there are free metronome downloads on the net that you can play on a notebook as you practice...
    http://www.webmetronome.com/
    after a while it will become second nature...
    on bracing that hand... things like the "Tigfinger" are becoming popular..
    http://www.weldingtipsandtricks.com/...tigfinger.html
    but there are lots of bracing methods.. do what works for you..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Default getting close
    you seem to be on the right track. .I notices that you had a lap joint and you burnt the top edge off. try not to do that and keep the tig torch slightly towards that bottom plate. heat will naturally reflect up towards the top plates,so favor the bottom a little. grip the tig torch close to the top and try keeping it about 5 to 10 degrees, pointed in the direction you going.
    as others have said practice.
    you will be ok.
    Feb 2014
    3
    Thanks for the help... need to get my bottle refilled then get back to practicing
