Thread: Oxy-fuel
    Default Oxy-fuel
    Could someone give me a ballpark estimate on the price of 10 cf of acetylene and 20 cf of Oxygen? I have used oxyfuel for cutting before but now I am interested in getting my own outfit but want to know how much the gases cost. I am in the Southeast U.S. Thanks!
    Aug 2012
    Hermiston Oregon
    286
    Call your lws for a quote.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Apr 2010
    311
    Get big tanks.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    PA
    372
    stick_welder13
    I own a 280 cu ft oxygen tank and it costs me $35 to have it refilled (actually they swap it out).
    Also own a 336 cu ft argon tank and it costs me $40 for a refill/swap.
    My set-up is propane so I am not much help with acetylene.
    I agree with USMCPOP - buy big tanks.
    You can buy small ( 80 cu ft ) oxygen tanks at a local Harbor Freight store but it may be frustrating since you don't get much for your buck. An added worry is the trouble of getting them refilled.
    Nov 2012
    Northern Arizona
    553
    The bigger you can afford, the better. You can look on craigslist for a set. Here in Southern Arizona there is usually a set of tanks with a 140 acetylene and a 200 oxy with a torch and cart for around $400. Keep in mind that what ever size you get acetylene has a draw down rating of 1/7th. So your 10cf acetylene tank could run a cutting tip or a welding tip that is rated for just over 1cfh. That is pretty tiny.
    Do a little research on the 1/7th rule and that might help you decide to get bigger tanks.
    Also, some interesting video related to the transport of flammable gasses: http://ihmusedparts.com/highway-hazmat-****/
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
