Results 1 to 2 of 2
    Aug 2008
    saskatchewan
    35
    Default Pro 300 auto/run switch
    My Pro300 will only idle up if I strike an arc or use AC for tools. Appears as though auto/run switch also used to start and stop machine is malfunctioning? Suggestions?
    Oct 2004
    Edmonton, Alberta
    8,351
    Quote Originally Posted by Azphiks View Post
    Probably replace the switch
