Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Dec 2013
    4
    Default Extremely clean looking TIG welds???? Picture
    Can someone explain what technique is used to produce this look on a TIG weld? I have been tig welding for 20+ years (mostly stainless and aluminum). But, I have never had a cause to tig mild steel much. Is it a special filler rod? Is it a helium/argon mix shielding gas?
    I really like these welds from an aesthetic point of view.
    Looks like MIG to me.....with a good setup....
    Quote Originally Posted by mcbassin View Post
    Who's are they?
    Quote Originally Posted by JerseyWelder View Post
    Feb 2009
    Lodi, CA
    1,294
    Those are TIG welds. The "Stack of Dimes". It has been discussed on this and other forums many times in the past, do a search.
    Salem ,Ohio
    3,928
    Cool
    Who's are they?
    Looks like Mike Jones Welding by the jpeg name...Bob
    Nov 2003
    3,328
    Smile
    You could be right...
    I have seen pulsed MIG with a good operator that looked like stacked dimes TIG....
    Could be either...
    Does look like stainless steel though..from the colors in the pic..
    and from the way the color of the HAZ looks and the beginning and end of the beads
    am going to guess TIG...
    Small pic.. tough to tell.......
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Oct 2009
    306
    It is most definitely tig, the technique is to dab filler and move forward and repeat, pretty straightforward. It's tough to say whether the parts are mild steel or stainless. The gold color on the bead means the shielding gas got great coverage and the weld wasn't too hot.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2013
    4
    Quote Originally Posted by jrscgsr View Post
    I agree, It's definitely TIG welded and I'm 99% sure it's mild steel base metal. I'm just not too sure about the filler metal. I frequently weld mild steel pieces with stainless filler because there is far less spitting and porosity when my foot gets too heavy.
    I'm thinking it's more than just dabbing the filler. I think it may require throttling back on the pedal for ea. "dime". I can dab perfectly in aluminum and stainless but never had much success with mild steel. I've never had luck making welds near this clean.
    Nov 2003
    3,328
    pretty easy to achieve that even spacing with "Pulsed TIG" using a machine like a Dynasty with built in pulsing capability... lots of machines out there these days that can pulse.... getting pretty common.. sure beats pumping the pedal..,,,,,
    My Blue Stuff:
    Millermatic 200
    Jan 2007
    Montana, USA
    236
    Where did you get the photo?
