Results 1 to 3 of 3
    Oct 2005
    Central Texas
    64
    Default MSW 42 Spot Welder Question
    I acquired a MSW 42 portable spot welder today and have a question.
    Is the on/off switch supposed to stay in the on or off position when activated ?
    Reason I ask is mine won't stay in the "on" position unless it's held there --
    makes it hard to squeeze the tongs while holding the switch on.
    Is that normal ? If not, is there a repair that can be done to the switch, or am I out $80 to replace it?
    Jim
    Millermatic 210 Dual Regulators & Tanks
    Spoolmatic 3035
    Miller Syncrowave 200
    Miller MSW 42 Portable Spot Welder
    8,346
    I believe thats completely normal as you certainly don't want those tongs live if someone bumps into it. Kinda makes sense doesn't it? The ones I work on are on a preset timed panel
    Oct 2005
    Central Texas
    64
    OK, if that's correct it sure makes it hard to use ....
    I'll have to get used to it.
    I may have to clamp the tongs on the metal, then hit the switch.
    Tried doing it that way today and it works good.
    Thanks,
    Jim
    Spoolmatic 3035
