Results 1 to 3 of 3
Thread: econotig
    Feb 2014
    Default econotig
    Hello I went to use my econotig today and the tungsten rod will not tighten up? Is there a piece that goes between the brass piece and the back black piece. I looked for a parts breakdown with no avail, the number on the torch is MT-1, thanks for the help.
    Sep 2009
    Colorado
    225
    Quote Originally Posted by harback View Post
    Take the entire torch to your local welding shop, they can figure out what parts you need, probably the collet. Just make sure that it all fits together before you leave the shop.
    Richard
    Nov 2003
    3,584
    Smile
    Quote Originally Posted by raferguson View Post
    Richard
    +1
    Likely that he torch is a #17 or #9 series... probably #17... they can tell you at the LWS
    Be aware that the torch will require a collet & collet body that matches EACH size of tungsten that you are using...
    For Instance: You may have a 3/32 collet and collet body set installed... and if you try to fit a 1/16 tungsten.... it will NOT tighten up... you will need the 1/16 set... they MUST match
    My Blue Stuff:
    Dynasty 350DX Tigrunner
