Thread: Trailblazer 302
    Aug 2010
    24
    Default Trailblazer 302
    Do the GAS powered 301 and 302 trailblazers have enough juice to run, I hate to say it on the Miller forumn, but a LN-25 ? Or will I be kicking myself down the road if I by one. Money is kinda tight right now so I cant really afford a diesel atm. Any recomndations or advise would be appreciated
    8,096
    Of course, now you HAVE to set your engine to 62.5 hz probes in the 120 vac receptacle terminals. On a Kohler the adjusting nuts are on the right side of the back of the engine near the exhast with a couple of 3/8" gland nuts. On an onan, the adjuster is above the right side valve cover. you have to loosen off a 10mm nut and adjust a 8mm/ 5/16 lock nut and tighten a adjuster bolt.
    Oct 2009
    alabama
    25
    I have a ln 25 and a vs 8 and they both run wire ok my 302tb. The vs8 or vs12 will be more compatible to the miller machine.
    asheville n.c.
    618
    Ln 25 will run fine...I do it all the time
    Illinois
    621
    Quote Originally Posted by beamwalker View Post
    Ok, Bless me FATHER for I have sinned .
    Cave Creek Az
    1,040
    Yep, works great on my TB251.
