Results 1 to 10 of 10
    Feb 2014
    Greenwich,ny
    32
    Default welding bracket on air compressor
    I got a older craftman air compressor that prolly around 15 yrs old! Its a horizontal tank 33gal, motor fried out! I bought a new 60gal for the shop! I want to take the old 33 tank an make it a vertical tank to save room on my mobile truck I am doing! So, my plan is to cut the old bracket off an weld it to the top, plus a few legs or stand on bottom! To risky? Just buy a vertical tank?
    1,920
    Only you know the condition of the tank. Being 15 years old it most likely has rust issues on the inside. They rust from the inside out. No one here can tell you if it is good or not.
    Air tanks can be welded if done properly but if they are weak it's just asking for issues. Being on a mobile truck you need to ask what if it starts leaking while on a job & you have to stop the job until it is fixed. What will that cost vs. buying a new tank right now.
    Dec 2013
    459
    I've had a number of tanks fail from rust. None have failed catastrophically. In my experience they begin to leak first, in each case at the lowest point on the tank. If you turn the tank 90 degrees, the old weak point moves. point it away from harm, once it leaks, scrap it.
    As for welds, I don't know your skill level. Maybe build brackets to clamp to the outside of the tank. After any welds to the tank, it should be pressure tested.
    Feb 2014
    Greenwich,ny
    32
    I understand where u guys are going! I am a decent welder, I can weld it the first time an have it fixed! Best to spend the money an get a vertical gas compressor already set up? Any suggestions? Thanks for the help
    1,920
    You might have a hard time finding a gas powered vertical compressor. They aren't that common.
    My vote is for a Honda engine, they are very reliable. How much air (cfm) do you need? Air tools, carbon arc?
    Feb 2014
    Greenwich,ny
    32
    Well get a vertical tank an mount a gas motor instead of electric! Mostly air tool(1/2 impact, 3/8 ratchet, chisel) eventually a plasma cutter! Have extra torch set to hold out till I get one! I was thinking around 14 CFM! 14CFM be to small? I work on a lot of agriculture equipment so its rusty as ****! I am not looking to spend more than needed, something to last a long time
    Jun 2009
    greenfield new hampshire
    889
    you own the tank, wont take long to figure out if it is any good, if i bought every thing that i wanted instead of building what i wanted, my skill level would be less and my wallet would be skinnier. i am a firm believer of fixing before replacing, just weld on some 14 to 10 ga. thick pieces of flat onto the tank where any leg ot what ever will be welded to the tank, thickness is not critical, just thick enough
    Apr 2011
    367
    Might want to open a port first...but you knew that.
    Just For Home Projects.
    Feb 2014
    Greenwich,ny
    32
    I mite go for it! I will pressure test it in the field just in case it blows up! I let u guys know, I got it cleaned an everything!Just got to weld an connect everything!
    Cave Creek Az
    1,082
    Exclamation
    Just remember, the motor and pump don't have to be mounted on the tank. Mount them where convenient then run a tube to the tank.
