Results 1 to 10 of 14
    Default Millermatic 252 Eats Tips and about 1 in 10 bad Starts
    I have a Millermatic 252 and it eats tips like M & Ms This is very annoying and expensive any Ideas
    Nov 2003
    3,581
    Question
    Quote Originally Posted by Richard Baird View Post
    tough to speculate without...
    what you are welding.. material & thickness
    machine settings
    gas & flow rate
    wire type and size... brand...
    contact tip size and style...
    wire stickout
    not to mention some pics of the "eaten tips"
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Oct 2004
    Edmonton, Alberta
    8,224
    If your using real Miller tips, you likely won't have this problem. If you are then its obvious that your wire is slipping.
    See, we don't read minds, absloutely no idea how old your gun is, if you've ever changed a liner, if your using clone (cheap) tips, condition, or correct size of your driver rollers,
    Feb 2009
    Lodi, CA
    1,305
    How is it eating tips? Is it burning back and fusing the wire, or actually melting the tip?
    Feb 2009
    Lodi, CA
    1,305
    Sorry, I just went back and re-read your original post, and the title. Sounds like you are burning back and fusing the wire to the tip.
    If it is not due to incorrect voltage/wire speed settings, open the machine up, check your capacitors. This happened to me with my LN-25, the capacitors were broke loose, bouncing around at the bottom, we replaced them with new, more secure mountings, no more burning back, or wasting tips.
    Oct 2004
    Edmonton, Alberta
    8,224
    Extremely unlikey in a 252, it would mean that his drive is bouncing around, and that would throw an error. His wire is slipping to eat tips. Whether or not its a failed liner, rolls, to cheapo tips is an unknown.
    Aug 2007
    Northern California
    209
    A welder such as the MM252 could burn tips and stick the wire if, as mentioned above, the wire is slipping in the rollers. Also, the user could have set way too much voltage and too little wire speed. It could also be a dirty liner or corroded wire.
    On my MM252, I changed the outer cover on the original torch to the one that permits a 1/8" recess for the tip. This shields the tip a bit more. I've yet to burn a tip, however, after a year of intermittent usage. I use only original Miller parts.
    Miller Syncrowave 200
    Milermatic 252
    Lincoln AC/DC "Tombstone"
    Nov 2011
    159
    Quote Originally Posted by Synchroman View Post
    I did just the opposite. Tip flush and no issues
    Oct 2004
    Edmonton, Alberta
    8,224
    Quote Originally Posted by ericher69 View Post
    The idea behind reccesing the tip, is for gas to wire coverage, and to prevent the tip from shorting to the work. Flush means that your working in a PERFECT enviroment, ie, no outside air movement, kinda silly really, as you may be using more gas than is required.
    Nov 2011
    159
    It is PERFECT! In the shop with NO air movement.
    Silly is chastising someone without knowing what works for them.
