Results 1 to 2 of 2
    May 2008
    Troy, MI
    350
    Default Some Weldments for FIRST Robotics
    I have been working as a Mentor with high school students for a local FIRST Robotics team for a number of years. Next Tuesday, February 11, 2014 is the day that we have to bag up our robot and stop working on it. Attached are a few things that I welded together.
    1. The first is a kicker weldment.
      This is the thing that will kick the 24” diameter ball.
    2. The second is the stop that will stop the kicker.
    3. The last is a bearing block holder to add a tail bearing to a motor, which will power the kicker. Notice the hexagonal bore in the bearing.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    350
    And here are the rest of the pictures.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
