Results 1 to 8 of 8
    May 2008
    Troy, MI
    350
    Default Snow Plow Bracket Repair
    Here in Michigan we have had a winter with so much snow that it has been very hard on the snow plowing equipment. Below is a welding project I just did to fix the bracket that mounts under the truck and supports the snow plow, for one of my customers.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    350
    Here are the rest of the pictures...
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Apr 2013
    metro Detroit
    91
    I can relate to that fix, I blasted a curb with my plow and have to pull it off to see if I need to do any repairs
    1,884
    Did you replace it with the same thickness or one size bigger? Looks like a fine job. Always nice to see someone cut it out & do it right vs. just globbing it back together.
    wisconsin
    116
    Nice job.
    May 2008
    Troy, MI
    350
    I believe that I replaced it with the size that it was when it was new.
    The plate had been thinned down due to rusting.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Aug 2004
    Milan Michigan
    1,778
    MMW, I was thinking the same thing when I looked at the first pick, and when I looks at the last one I said great, He got rid of the fatigued metal.
    Just welding it back is cool to get you back plowing to finish but is just going to break within the next couple of storms.
    Good Job.
    Jul 2008
    Flin Flon & Creighton area
    233
    very nice job , that will get them going again!
    I have a welding addiction
