Results 1 to 9 of 9
Thread: Torch
    Sep 2013
    Langhorne,Pa
    17
    Default Torch
    Hi Guy's
    Need a recomendation on a tig torch,need flex head,front load,small, to get inside intake runners on aluminum cylinder heads,any ideas..
    Thanks Dean
    Miller Dynasty 350
    Lincoln PT 375
    Miller Trailblazer
    Lagun 10x50 Vertical Mill
    Southbend 9x30 Lathe
    Kwik-Way Valve Grinder
    Victor O/A Set
    Delta 10" Vertical Band Saw
    45 Yrs. worth of hand tools & a couple hammers
    Custom Built Cylinder Head Flow Bench 1400 CFM
    Nov 2003
    3,622
    You might consider adding a stubby, like a water cooled #24 and a pencil torch to your collection for tight work..
    I have never been a big fan of flex heads...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Nov 2003
    3,622
    You might look at Marcella's videos and see what torch he is using in tight quarters...
    http://www.millerwelds.com/resources...086#post318086
    the other videos might be fun to watch too... pertaining to Engine Building...
    My Blue Stuff:
    Millermatic 200
    Quote Originally Posted by H80N View Post
    or a CK micro tig torch
    HTP Invertig221 D.V. Water-cooled
    Eastwood MIG175 w/spoolgun
    Eastwood Versacut40 Plasma cutter
    Sep 2009
    South Carolina
    571
    I purchased a Flex-loc maybe nine months ago or so. Thought I would put it on today but lost the little wires used to tie the hoses on.
    Having to get in a tight place and weld aluminum would be tough.
    Quote Originally Posted by Hardrock40 View Post
    yours doesn't use the screw-type fittings that compress the hose over the barb?
    Even then, some 0.023" or 0.030" SS304 mig wire will do the trick in a pinch.
    Sep 2013
    Langhorne,Pa
    17
    Been awhile but still looking for a small torch,watched Marcella's videos but can't identify what torch he is using,e-mailed him awhile back but never heard back,anybody have any idea's what torch it is?
    Miller Dynasty 350
    Lincoln PT 375
    Miller Trailblazer
    Victor O/A Set
    Dec 2010
    northern california
    9
    Quote Originally Posted by Engine Builder View Post
    It's a Weldtec torch, WT-24WF. I bought the same torch for a job I had to weld. I bought mine from IOC. I also just bought the CK micro torch, you can get into a 5/8 tube with this one.
    Quote Originally Posted by Invader28 View Post
    Be VERY careful with those little Pyrex cups that come with it. They break if you look at them wrong! Already broke one. I'm going to order some of the alumina-version of those tiny pyrex cups, and use them instead, unless I absolutely have to use the Pyrex ones.
