Results 1 to 9 of 9
    Default setup to weld 18 gage sheetmetal panel
    hello everyone, can anyone tell me the set up process I would need on my diversion 180 torch to tig 18 gauge sheet metal panels.
    thank you
    David
    Dec 2010
    Andover, Ohio
    132
    Hi and welcome to the forum David.
    Dec 2013
    At the epicenter of the Green Mountain Range in VT
    385
    Quote Originally Posted by Silverlostdog View Post
    thank you
    David
    Are we talking about steel? But, overlap, corner?
    Default 18 gauge sheetmetal panel
    thank you for the quick response.
    I am wanting to start to weld on body panels for auto body, butt weld would be it.
    right now I am welding on 1/8th mild steel with a 3/32 gas lens and 3/32 collet and I am getting fair results and starting to really like this diversion 180.
    thanks
    David
    Nov 2012
    Northern Arizona
    538
    I thought the diversion had a quick setup right from the front panel? You'll probably want to switch to a 1/16" tungsten though. Straight polarity. And i would guess 40-50 amps, but I haven't run the diversion so I don't know how it welds. Do you have a pedal?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Dec 2013
    385
    I would choose the tungsten you have, sharpen to a needle point, stay away from pure tungsten. 20 CFH argon. Set heat to where you burn through a scrap piece in 4 seconds, then use your pedal to avoid burn through. You are at a slight disadvantage with TIG in that it gives a larger heat affected zone than MIG. Minimize this by using quick heat, then get off it. A series of tacks alternating across the patch, keep the patch as small as practical. On a jeep you have flat surfaces, when the weld seam shrinks, it leaves the field puckered. Heat shrink these, and hammer and dolly on the seam.
    Congratulations you have a great machine for thin steel. If you don't have a pedal, get one.
    Nov 2003
    3,435
    Default Butt Welding Clamps
    You might want to get some of this style clamp.... they are available many places inexpensively... try fleabay
    http://www.youtube.com/watch?v=OkFhfKcjbQQ
    the TIG technique would be similar to what they showed w/MIG...
    but much shorter stitches.. skipping around to minimize warpage
    Take some time and practice on some scrap until you are confident with the technique...
    for amperage... start out @ approx 1amp per thousandth thickness to get into the ballpark and adjust from there..
    work that out on your practice pieces NOT on something that matters...
    do not expect warp free sheet metal TIG butts overnight... it can take years of diligence to get there... and still require planishing with a hammer and dolly
    Practice..practice..practice....
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Dec 2013
    385
    Keep an air hose handy to cool each tack immediately to minimize warping. It will have little affect on hardening mild steel.
    Oct 2006
    Illinois
    623
    Harbor Freight has them. Use a coupon and save more.
    http://www.harborfreight.com/8-piece...mps-60545.html
