Results 1 to 3 of 3
    Feb 2014
    1
    Default miller aead 200 le problems
    Hey i have a 85 miller aead 200le serial # Jg137113 with a b48m onan engine. When i first bought it about a year ago it welded fine.. Now it seems like its losing power. Used to be able to weld a 5/32 7018(approximatley 165-175amps?) not it barely welds a 3/32
    7018(100 amps max) ... And when i start welding and put a load on machine, engine boggs down n runs at low speeds almost to where it dies but hasent yet. And the engine is leaking oil from somewhere around the left side head cover.. Oil everywhere.. I havent cleaned the oil off to see where its comming from yet. I took the covers of the welder today and cleaned out a bunch of dirst, dust, grime, leaves, and dirt dobber nests. The fine tune rheostat had like some gunk caked up on it so i took a wire brush to it and looks alot better.. Pretty much cleaned everything... Havent tried to run it agin yet.. Thinking about trying to fix the oil leak before i run it anymore... Any thoughts or solutions to these problems would be much appreciated.. Thanks
    Apr 2013
    Southeast idaho
    30
    One thing to think about is if a crankcase seal has blown I would check the breather to see if it was bad to. But see where the leak is at first.
    Aug 2008
    Orange, TX
    1,225
    PM and email sent.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
