    Default bubble in weld leave pin holes
    I am welding an aluminum (6061) part that is 8.75 long. I start with a tack weld at the ends on material that is 1"x.5"thick and then weld the center which is .050 thick. In the ..050 thick welding I have no problems ( I am purging the back with 100% burn through), however, when I butt weld the ends which are thicker (1 x .50) I see gas bubbles starting to escape. I try to slow down to let the bubbles dissipate but when the material is cleaned up the pin holes are still there. The material is being welded with 4043 rod the ends call out an .125 bevel , it is immaculately clean (it is cleaned with acid etch and stainless wire wheeled. The weld is not dirty it welds clean but no one seems to know why the pin holes keep forming or why the gas bubbles form.
    The machine is a Miller 350 Lx with 10 PPS and 2% thoriated tungsten is 3/32 with a glass lens.
    Nov 2003
    3,518
    You might try using 4943 filler
    it seems to be a bit more fluid and is really good on 6061
    http://www.millerwelds.com/resources...Casting-repair
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2009
    306
    Sounds like the joint is sealing, then as you are almost completing it there is pressure created by the expanding gas and it is contaminating your weld from inside the joint.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Nov 2003
    3,518
    Smile
    Here is a MILLER video on the subject of "Aluminum Porosity"
    it's Causes and how to avoid/minimize it...
    http://www.youtube.com/watch?v=Yu3BtdERmFM
    By Tony Anderson, Head of Aluminum Technology Miller/ITW
    Here is the updated literature he referred to
    http://www.hobartbrothers.com/downlo...minumGuide.pdf
    Porosity starts on page 24 of the flyer (page 26 of the pdf)
    My Blue Stuff:
    Dec 2010
    Andover, Ohio
    139
    Welcome to the forum Artfusionwelder.
