    24
    Default Welder identification
    Can someone help with the id of this welder?
    It has blue paint on the sides and top but I am not sure if its the original color.
    Ther are no serial numbers or model numbers
    The only number I can find is on the inside bell housing
    It says 54459
    There is also the letters WF stamped below
    It has a Kubota D850 engine
    24
    2,967
    I think Lincoln uses Kubota
    24
    I heard that Miller built Airco
    But I cant find that they used kubota engines
    24
    I can not find anywhere that Miller put Kubota engines in the models they built for airco.
    Maybe Esab made it?
    24
    I found a picture of a airco 275 welder at a auction site its the only picture that matches the front panel.
    Does any know what miller welder this would be closest to?
    8,351
    You found a picture, well thats great, and its WHERE?????? MY ESP isn't kicking in
    Apr 2010
    322
    You have to have the premium cable package. It's not on regular Welder TV.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
    24
    Thats the one. Thanks
