Results 1 to 10 of 19
    Nov 2013
    12
    Default Onan p216g interchangabilty
    ok, I bought a miller bobcat 225g with a onan p216g. I had always wondered why it puked out oil out of the fuel pump. needless to say i found out what was causing it. I found that I had 2 bent intake valves and lost the seat in on of them and as of right now the engine is FUBAR'D as of right now. So here is the million dollar question of the day... The welder is a 1991 model according to MILLER, so I am guessing the engine is a 1990-1992.. I found another p216g with very little run time, but before i do that i was wondering if these engines will swap out or if I am going to run in to problems with the crank mating to the generator...
    Jan 2014
    Northern West Virginia
    37
    Default Don't take my word on this but check it out
    I believe that engines that are designated for use with generators usually have tapered shafts whereas other engines use straight shafts. See which yours has and limit your search to them. Also, and once again this is just my understanding so you'll have to check it out yourself, but I think the mounting holes and bolt patterns are more or less universal for various sized engine platforms and generators, so you may not even have to limit yourself to the original brand and model of engine if you are getting one of about the same horsepower.
    And with that said I wish you all the luck in the world finding a 20+ year old used engine in good repair.
    Nov 2013
    12
    Default called cummin/onan
    I found out today that for that engine there was 11 different crankshafts, I don't know if they are generational or by application. But I guess the only way I am going to find out is to get the full numbers off of both engines and run them to see if they are interchangeable. And you do bring up some good points as far as mounting. I have heard that some later model p216 in a miller application were threaded.
    1,884
    Maybe change the title in your thread to reflect your question. Something like Onan P216g interchangeability.
    Nov 2013
    12
    Default Thread title
    Noted sir!!! Didn't even think of that!
    8,020
    Old engine has a code on the data plate, the new engine must have the same code
    Nov 2013
    12
    Default data plate
    So the data plate on the engine has to match character for character?? So if that is correct I need to find a 20+ year old engine with low hours? Or drop about 1500.00 on a new engine?
    I wouldn't think there would be THAT much variance in crankshafts, with the exception of narrow taper, wide taper and threaded.
    8,020
    Lots of variations, thats why the engines have a specific code
    Sep 2009
    Canada
    189
    Have you looked into the cost of overhauling your engine?
    New valves, guides, springs, cam shaft etc.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Nov 2013
    12
    Default engines
    Cruizer, I found that out when I called Cummins/Onan, lol. I could not believe how many variations there were!!! But I reckon all I can do is get the numbers and run them.
    Snoeproe, I was told by my mechanic that between machining and rebuilding it I would be money ahead to just buy a new one, because the valve seats would have to be oversized among other things. He also said that if I could find a used one that wasn't wore out that may be my best bet. I don't have a lot of money to blow on a engine and, I found one that would be pretty much just given to me. But it has to be the correct variation of that engine. It is on a small Case lawn tractor.
Tags for this Thread
