Results 1 to 3 of 3
    Jan 2014
    1
    Default Need help hooking up Air-Cooled TIG torch to Miller Pheonix 456!
    I have a Weldcraft TIG torch and a Miller Pheonix 456..........how do I put the two together? Its gotta be pretty simple but I cant find any other help on the web
    Nov 2003
    3,629
    Quote Originally Posted by smrode View Post
    I hope that the torch you have is one with the built in gas valve...
    because I am not seeing a gas solenoid on the Phoenix... I could be wrong..
    http://www.millerwelds.com/om/o2213h_mil.pdf
    you wll need a powerblock to connect the torch to the Phoenix
    it is a 45V62 200amp for a large air cooled TIG torch that has the integral power cable built into the hose...
    Pretty self explanatory... it connects to the welder power stud... one side threaded for the fitting on the torch... the other side accepts standard argon gas hose fitting that goes to regulator and gas bottle..
    http://www.arc-zone.com/index.php?
    main_page=product_info&cPath=13_673_678_2141&produ cts_id=576
    the Phoenix does have the standard 14pin connector so you could use a RFCS_14 pedal..
    (see the manual)
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Oct 2004
    Edmonton, Alberta
    8,281
    What I do, is merely get myself the dinse or reg camlock connector that goes into the machine and a tig block. Then I braze the 2 together. Easy peasy.
Tags for this Thread
