Results 1 to 3 of 3
Thread: mm250
    Jun 2009
    greenfield new hampshire
    889
    Default mm250
    i am having a discussion with a friend about the mm250, i did own one recently, sold it to buy a tig, i have had and still use a mm200, i know very little about the 250, the one that i had had volt and amp/ipm gauges, it was a digital readout, my question. has the mm250 always had the digital gauges, i am thinking that it did when miller upgraded from the mm200. but i am not sure, any one know, much appreciate any input
    Dec 2011
    436
    I looked at the 1st and the last of the manuals for the MM250 and it looks like the 1st has no meters and on the last it was an option.---Meltedmetal
    Jun 2009
    889
    thank you, posted many a question about this, and i still havent got to the bottom of this issue, you just nailed it, now i can move on, and share that info in the discussion that i am having. it was optional, and you found it in the latest manual. thanks again. kevin
