Results 1 to 10 of 12
    Jan 2014
    6
    Default Trailblazer 250G runs but doesn't generate anything
    Need a little assistance, I have a welder s/n KB145838 that doesn't generate much voltage. I tried flashing it at wires 17 &19 and didn't get and sustainable change. Fuses are good, I get .6 volts across wires 14&15 with unit running and 2 volts at outlet. Any ideas? Thanks
    Feb 2012
    226
    Have you checked your brush length or cleaned the slip rings ?
    Jan 2014
    6
    Do you have what the tolerances should be, I ohmed them out and they seem ok. Also can you clarify for me, how does the exciter coil create the AC voltage. Is it through the rings and brushes? Thanks
    northern NJ
    1,910
    Didn't have much time to look up what year machine you have but read through this.
    http://www.millerwelds.com/resources...highlight=250G
    MM250
    RCCS-14
    northern NJ
    1,910
    MM250
    RCCS-14
    Oct 2004
    Edmonton, Alberta
    8,252
    Manually exciting it probably was stupid, as the unit has an exciter board. You likely took out a diode in the line. Since your f1 fuse was ok, the brige it protects is ok. Your exciter board is the likely culprit and the the diode inline with wire #18 is now poofed.
    Jan 2014
    6
    Thanks for info fellas. Cruzier, this unit has only one board and it's called the Field Current Regulator Board. Is that the same thing as the exciter board?
    Jan 2014
    6
    I meant Cruizer
    Oct 2004
    Edmonton, Alberta
    8,252
    You want to check for resistance between wires #28 and #15. pull these wires of bridge SR3. If you get less than 5 ohms, this circuit is happy, if not then this circuit is toast, and there is nothing you can do about it. Generator is trash.
    If it measures well, brushes are good, clean the the slip rings with a fine emery cloth splashed with brake cleen. If this all fails then yes its that regulator board
    Jan 2014
    6
    Cruizer, wires 15 & 28 ohmed at .4 ohms between them disconnect from the SR3. We swapped the board out with a good one from our other 250g trailblazers as one of the first things that we tried and got the same results. I'll try to clean the rings and take a another look at the brushes . Thanks again.
