Results 11 to 14 of 14
Thread: miller scp-200c
    1,880
    Did you read the other replies? You need to have the feeder hooked up to close the contactor to get output.
    Did you download the manual?
    Did you check that the unit is set up for your input voltage?
    Nov 2003
    3,324
    Smile
    Let's take a different approach.... Now bear with me...................
    What model and serial number is the suitcase feeder..?? pictures..
    The power supply will NOT function without having the feeder (or reasonable electrical equiv/jumper) connected..... they are interconnected and interdependent .... special connectors that provide power to the feeder and connect/actuate the feeder
    so...... lets check out the feeder
    and if all looks good we might plug int the two smaller cables (115v & Contactor) into the front panel of the power supply and see what happens..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2013
    28
    Default miller scp-200c
    Ok I plugged the feeder in and it dose noting it keeps blowing the 10amp fuse on the welder, the feeder is a millermatic 80A serial number is JA435820,
    Nov 2003
    3,324
    Quote Originally Posted by DPSwelder View Post
    Guess you did not read ALL of my last post...
    the part about checking out the feeder BEFORE plugging it into the power supply..
    I usually check things out first... I'm not brave enough to go straight to the SMOKE TEST..
    here is the manual for the feeder
    http://www.millerwelds.com/om/o1038c_mil.pdf
    I would open the covers and do a visual check of the feeder...
    check the condition of the cables... a damaged/shorted 115v cable or connector will instantly blow F1 on the power supply..(not unusual on old well used equipment)
    and READ the feeder manual...
    My Blue Stuff:
