Results 1 to 10 of 14
Thread: miller scp-200c
    Oct 2013
    28
    Default miller scp-200c
    Hey guys some 1 just gave me this welder and I don't know that much about It so I'm hopeing 1 of all u guys will here's a few pics
    Nov 2003
    3,324
    Thumbs up
    Quote Originally Posted by DPSwelder View Post
    Gave it to you??
    You made out like a bandit...
    if that suitcase feeder came with it..
    you have a complete BULLETPROOF... single phase MIG setup..
    http://www.millerwelds.com/om/o201f_mil.pdf
    270 Amps @ 35% Duty Cycle...
    should be able to strap the input for 230vac single phase..
    (wants a 50Amp breaker for full output)
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2013
    28
    Yeah the guy gave me both of um,I was wondering were I can get parts for these things
    Nov 2003
    3,324
    what type of parts??........
    very little to go wrong in the power supply and other than the big inductors... most parts should be generic off the shelf capacitors, diodes etc..
    on the suitcase... what model is it..??
    My Blue Stuff:
    Oct 2013
    28
    The power source will not turn on so I called the guy ho gave it to me and asked if he ever had it working and he said that it want under water like 6inchs, what do u think the problem is thanks.
    Nov 2003
    3,324
    Flooded...??.. oooo that makes it more interesting...
    First...pull the covers and see what the insides look like ...
    I would refer to the manual and make sure it is strapped for the proper voltage in your shop.. check connections, fuses etc..make sure it is actually getting the right power... also troubleshooting tips in the back of the book..
    also there is an internal contactor that is controlled by the contactor control receptacle on the front panel... would check that circuit too..
    it did look very clean from your pics....
    My Blue Stuff:
    8,005
    Water shouldn't hurt it much, but yes take it apart and pull the greables out of it. I pressure wash units, hasn't been a problem as long as its dryed out. So you've change the power input to yours right. Now the unit will not supply any output till a feeder is hooked up
    Oct 2013
    28
    I got the fan to work but I don't have any power going out, what dose that mean all help will be Appreciated thanks.
    Nov 2003
    3,324
    Look at section 3-5 Contactor control on page 8
    Gotta have contactor closure to have welder output..
    My Blue Stuff:
    Oct 2013
    28
    I'm not geting any power to the cable connectors It's like the transformer is bad in it or something,sory if I sound like I don't know what I'm doing,and that's because I don't lol I I am no Electrician.
