Results 1 to 10 of 20
Thread: 304 SS Dome
    Nov 2012
    Northern Arizona
    566
    Default 304 SS Dome
    I am looking for a supplier for a tank head type dome made of 304 stainless that has reasonable prices for a one off order. I want to build a prototype of something and if it works well I'll be order more. I'd like to have an ID of 16" and a dome height of around 4". I have been through most of the products at toledo metal spinning and haven't found anything off the shelf that will work. They could probably make one for me but that could add up quick. Thanks.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    alabama
    752
    Pipe caps. Although at that size 16 inch is the O.D.
    http://www.st-pipefittings.com/ANSI%...-end%20cap.pdf
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Nov 2012
    Northern Arizona
    566
    I am looking to build something like this: Brewhemoth tri-clover.png
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    1,919
    Tank heads have always been expensive especially in low quantities.
    Didn't say what your thickness is. Why don't you go to this website I saw on Miller videos Covell.Biz maybe this will help you.
    Nov 2012
    Northern Arizona
    566
    Thickness is a good question. I am back and forth between 16 and 18 gauge. So pretty thin.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    PA
    374
    elvis,
    Here is a sculpture I made which measures 18" in diameter.
    Used a wok for the form which cost me $19 at my local Asian grocery store.
    You mention that you can use 16 to 18 gauge material.
    Granted it's not stainless which is what you need but maybe
    you can mock up a prototype cheaper with one of these.
    They come in sizes from 12" to 30".
    I may fill this one with concrete and use it as a form to hammer out a sheet of .040" stainless to make a stainless wok.
    Looked at ASME pressure vessel ends in stainless to make a rust proof wok but gave up when I saw the prices.
    Good luck with your project.
    Nov 2012
    Northern Arizona
    566
    After pricing stuff out I might just buy a conical fermenter. I can buy it for $650 or build it for a little less. It sounds like a fun project but too expensive when you add my time into the mix. Maybe another time.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Dec 2012
    Simcoe Ontario
    108
    Default 304 SS Dome
    You could just make an orange peel cap out of piping ?
    Nov 2012
    Northern Arizona
    566
    Nathan-
    Normally I would say yes but I don't think I could get 16ga 304 pipe in a 16" or 18" diameter
    Burnt-
    I could probably make a mold and just use a 20ton press and make my own domes. Interesting idea.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
