Results 1 to 9 of 9
    Default Is it possible to hook to welders together to air arc?
    I have heard that it is possible to hook 2 dc welders together to air arc does this work? Would it work to hook 2 xmt 350s together to air arc? would that be harmful to the machines? Would they be back feeding to each other? Thanks Jerry
    Nov 2003
    3,841
    Quote Originally Posted by still learn'n View Post
    Miller has a booklet on paralleling power sources...
    http://www.millerwelds.com/pdf/Paralleling.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Dec 2010
    Andover, Ohio
    183
    Welcome to the forum still learn'n.
    Nov 2009
    western mass
    213
    not 100 percent sure but I would think 1 xmt 350 would burn a 1/4" rod? just don't turn it up to its max. maybe cruiser will chime in here.
    Apr 2012
    Ohio
    47
    air arc is VERY HARD on inverter machines. I would not do it very often with an XMT!
    Nov 2012
    Northern Arizona
    571
    Why it is hard on inverters?
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Salem ,Ohio
    3,974
    Cool
    Quote Originally Posted by elvis View Post
    They heat up and the digital readout goes wacko and after a few minutes you seem like you are running on 1/2 the amps then where you started. Saw it everyday when the smart people where i used to work "scrapped" all of our old 500 amp transformer machines and went with cubes of inverters. They just would't cut it...Bob
    Thanks for the welcome! We have done it off and on for a while now and havnt noticed any problems! We only have single phase power so that is why I was wondering about hooking 2 together. Sorry for the ignorance but what would be the biggest transformer style machine that would be able to run on single phase? thanks for the replies! Jerry
    Oct 2004
    Edmonton, Alberta
    8,351
    See you only want to turn your local control to 3/4 while gouging. You'll still get full output but the boards in the machine need to know whats going on. And yes if you do overload the machine output will drop in half. This is to protect the machine from nuking itself. This applys to ALL machines while gouging or running too heavy, be it transformer or inverter based.
