    Sep 2013
    Langhorne,Pa
    13
    Default Dynasty 350 Memory programs
    350 Memory
    Hi Guys,
    I have been using my 3 week old dynasty(sweet machine)almost every day and have a problem with saving setups in the memory,if i setup the paramerters in say #2 and set the EN/EP for "same" and add all the other settings and then add another program in #3 and set EN/EP for independant and add all other settings and then go back to #2 saved program the EN/EP that was set to "same" is now changed to independent but all other settings remained the same,hope that made sense....is there something i'm supposed to do like a save button or something,i'm sure it is something i'm doing wrong.Any ideas? Thanks for your time,Dean
    Miller Dynasty 350
    Lincoln PT 375
    Miller Trailblazer
    Lagun 10x50 Vertical Mill
    Southbend 9x30 Lathe
    Kwik-Way Valve Grinder
    Victor O/A Set
    Delta 10" Vertical Band Saw
    45 Yrs. worth of hand tools & a couple hammers
    Custom Built Cylinder Head Flow Bench 1400 CFM
    Oct 2012
    yuba city, CA
    55
    Default saved programs?
    Quote Originally Posted by Engine Builder View Post
    350 Memory
    Hi Guys,
    You need to read, step-by-step in the manual, how and what is said about entering programs, editing, saving and exiting; then practice doing the same.
    The settings are automatically saved upon exiting, but one has to actually exit that program; which you may or may not be doing.
    There's a longer learning curve to the 350 than other machines without extensive menus.
    Sep 2013
    Langhorne,Pa
    13
    So i have to close out one memory program before i go to enter the parameters in another program,i'll try it tonight and let you know.
    Miller Dynasty 350
    Lincoln PT 375
    Miller Trailblazer
    Victor O/A Set
    Oct 2012
    yuba city, CA
    55
    Default 350 menu programming
    From your comment above---you need to study that manual on doing this. It can get confusing and frustrating.
    You need to have the manual by the machine and read/do, step by step what they're saying, (turn knob, press ____, press ____, etc.)
    It takes careful study at doing what they're trying to tell you to do!
    It's not user friendly, intuitive, etc. If I get screwed up, then I just
    have to calm down and muddle thru the manual's instructions.
    Lots of practice in entering and exiting the menus and the sub menus helps. There's basically an infinite number of settings one
    can make.
    Sep 2013
    Langhorne,Pa
    13
    Thats what i have been doing,if i set EN/EP to same in one memory and set EN/EP in the next memory to Independent and you go back to the first memory that one will be changed to Independent but all othe settings are what they were orginally set to...EN/EP is the onlt thing that changes.
    Miller Dynasty 350
    Lincoln PT 375
    Miller Trailblazer
    Victor O/A Set
    Oct 2012
    yuba city, CA
    55
    Default need instant help
    owner's manual:
    section 5-1 page 39 Controls
    section 5-14 page 48 program storage locations
    section 6 page 54 advanced functions
    section 6-5 page 66 independent amplitude selection
    It's very easy to 'think' you've set something--when you actually have not.
    Getting used to setting this up, isn't going to happen by simply whining for help on a forum, it is more than a 5 minute job of learning--which many others have had to do. There's info in those 44 or so pages that will help you, short and long term.
