    Jan 2014
    Default Welding Repair to Excavator Boom
    I have a mini excavator - Volvo EC25 and there is a small crack on the corner of the boom. It runs approximately 1 along the side and 1 across the back. It is just above a thumb clevis plate that was welded on a few years back. My intent is to remove the paint, V-groove over the crack, drill holes at terminations of the crack and weld with 7018 rods. Am I overlooking anything? Should/can I grind the weld flat?
    Dec 2013
    451
    Quote Originally Posted by BrianK View Post
    You say boom, do you mean dipper? the thumb wouldn't be attached to the boom. Did the welding of thumb stress the dipper? Might it be made of ductile iron?
    Oct 2008
    Plymouth, MA
    6
    Last one I did was an Hitachi 200, they snapped the dipper in 2. I gouged it out, preheated, welded with Hobart Excel Arc 71 dual shield and then plated it. The maniacs have been snapping trees with the shear since I fixed it and we have no problems to report.
    Dec 2013
    451
    Quote Originally Posted by TozziWelding View Post
    Nobody local sells Hobart electrode. Is there a generic designation for Axcel Arc 71, or can it be had online?
    1,916
    Yes you can buy it online or most LWS can order it. It is Excel not Axcel.
    Other manufacturers have similar wires also.
    E71T-xx, dual shield
    Will Argue for Beer (any issue, either side)
    Dec 2013
    451
    Quote Originally Posted by 4956 View Post
    If you're willing to argue for beer, you would go to war for cider!
    Dec 2013
    451
    Sorry typo. Mrs. B was trying to drag me out the door.
    Aug 2004
    Milan Michigan
    1,866
    Answer to your question, Yes you can grind it smooth provided you have a great root pass.
    If your not experienced doing root passes like a pipe welder than your better off leaving the weld on there to compensate for a bad root pass.
    It is however a good idea to round your corners.
    Some will call it a Dipper or stick or Dipper Stick.
    When they really lay the boom or stick open, I prefer to add bracing on the inside and grind smooth.
Tags for this Thread
