    Default Miller SRH-333 HOT HOT HOT
    Community College I go to has me working with an (VERY) old SRH-333. Not happy since there are Dynasty 200DXs like the one I have at home locked in the cage where we cannot use them.
    Anyway, I have a query in to Miller for a manual as this one's S/N is so old it's not listed. S/N starts with U.
    Has anyone ever worked with one of these machines? This thing burns hot like there's no tomorrow. For example 7018s I'd run on 130 amps I have to run at 70. Have to adjust down similarly for all other rods.
    Is this just the way these machines were or is it this specific machine with a problem? Possible to fix this thing?
    Think I'm going to have to make them let me do my classwork from home so I can run beads well enough to pass the class. :-)
    Nov 2003
    3,818
    Smile
    Quote Originally Posted by stickermigtigger View Post
    Unless I am mistaken.. a Serial beginning with "U" would fall between Serial Numbers T453406 through HG065957
    So this should be the proper manual..
    http://www.millerwelds.com/om/o230_mil.pdf
    anyway... it sure looks like it to me..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    8,351
    Field control bridge is weak/damaged. No biggy, just get someone to change from the old style to the new style. Part costs like 5 bucks. Get it from an electroniics store. Looking for a 30 amp 800 volt unit. (volts is just the heat rating)
    Miller said this machine was mfgr'd in 1969 (I was a senior in HS :-)) and the manual can't be downloaded. They sent me the one published for it in 1971 - iom230e_mil.pdf
    Looking through the parts list I don't see anything called a "Field control bridge".
    Could it be called something different?
    Thanks folks.
    8,351
    Rectifier, 40 amp 800 volt left side upper center frame. All SRH's are the same for the last 50 years, body has changes, but not the inside
    Nov 2003
    3,818
    Thanks folks.
    Could be wrong but it looks like "SR2" on figure 7-1 page 11 of this one
    if they were using selenium rectifiers... the resistace across the junctions increases over time .. dropping the control voltage for the magnetic amplifier allowing greater current flow than the knob setting would indicate...
    the upshot is to do what Cruizer says and replace the bridge with a modern silicon rectifier bridge,,
    My Blue Stuff:
