Results 1 to 2 of 2
Hybrid View
    Default Miller CP-302 Help
    Hello to everyone, new to this forum.
    We are having an issue with the voltage crank on our Miller CP-302. When the Voltage hand crank is adjusted nothing changes/happens. We removed the panels, and found the rigging assembly moves back and forth the transformer when the voltage crank is spun. Our output just isnít changing. Is there any other troubleshooting advice anyone could offer?
    Oct 2004
    Edmonton, Alberta
    8,351
    Control board is damaged, replace it and all will be well
