Results 11 to 20 of 23
    Default Dynasty 200. Welcome to the site
    Yes, the Miller home office is in Appleton, Wi
    It has about a million sq ft of manufacturing.
    There are also a number of manufacturing business units surrounding the Appleton area. The TIG products are in a town called Greenville, next to Appleton and that is where the Dynasty products are made.
    Miller has its own circuit card design and assembly area at the main facility in Appleton.
    The foot controls are also made in Appleton and they do use a clogged belt/gear driven potentiometer. And as you stated, it is a simple design and yes it is reliable.
    Out of the 800 Motorsports machines I'm responsible for, foot pedals are the least of my concerns. I can say I've never had one just "jump" a cog or fall off!!?? If you've ever taken one apart, you'd see it's about impossible to fall off since its under spring tension and the clogged gear has a shoulder on it.
    My biggest problem with foot pedals is people dropping crap on the cables and cutting the wires.
    I have seen some potentiometers wear out over a long time of heavy use but those are easy to replace. You'll have that with any type potentiometer from any manufacturer.
    Another design feature unique to the Dynasty 200 is the inverter engine.
    Our engine is a universal design that works on any input power variation from 100V to 600V single or 3 phase. Other manufacturer's only work in certain voltage ranges like 120 V or 230V but not anywhere in between. So if you are using a 230 V input, if the power drops below 200, or whatever their "tolerance" is, your out of luck.
    The Dynasty will run on anything.
    I've even ran it on a generator that was running out of gas and the engine was hunting all over the place.
    You also asked about transformers...
    Since this is an inverter, there are no typical transformers. This is an electronic power conversion process. The transformers are extremely small and built with a special Litz wire. They don't fail.
    Miller does make it's own transformers for welders AND rotors/staters for engine driven products.
    Hope this helps you decide.
    Ultimately, I hope you get to try one. You know what opinions are like
    A-
    Corunna Ont, Canada
    455
    Default Dynasty 200DX
    Quote Originally Posted by kize View Post
    Ive found just the opposite. For every one positive post - there are 10 complaining. Very few spend time expressing their happiness with a product
    This is the same old things about planes, some people say planes are unsafe....
    That's only be cause you only hear about the one that crashed, not the 100,000 that flew fine.............
    I bought 2 200's a few years ago, and just love them, had a invertec 205 which is the direct one to the miller(well as close to the same) and it's not a bad machine but the miller is just higher on the scale.
    I took a tour of the Miller plant in Appleton from Andy and what a place just awesome, so I asked why miller had so many more inverters over the red, simply put: Miller owns the patents to the inverter technology.
    Sone of the tests they put on these machines before you get them is pretty hard on them, to get one that does not do what it should is not very likely.
    If ya ever get a chance to see it, it's worth it.....
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Mar 2013
    19
    Default rigorous testing hmmmmm
    Hey Railmen,
    while you did the plant tour, did any of the guides mention specific industrial models like the dynasty/maxstar 300 series or the aerowave models?
    Maxstar300lx
    Buy once cry once!
    Corunna Ont, Canada
    455
    Default Plant tour
    Quote Originally Posted by maxstar300LX View Post
    Hey Railmen,
    Maxstar300lx
    Hummmmmmm, never really asked about anything certain, but did see CST280's right off the line, hook up, power up, turn wide open 280 amps for 1hr straight if it's going to break I think that is where it will happen
    Railmen
    2004 Invision 354MP
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    Hyperthrem 600
    2003 XMT 304CC/CV
    1963 Lincoln SA200G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Let's agree to disagree. I enjoy your posts H80N. I am a fair person for the most part. I do have to disagree to an extent. Miller is a great company. So is HTP. I do not buy stuff for myself based on where it is made. I buy it based on quality. Example(I have a BMW M roadster for weekends), Mercedes are twice the price of Toyota but you have a hard time finding one that will outlast the Toyota. Check Toyota resale vs Mercedes....I had a 200dx and I have used a 350....I liked both. I also replaced a $1000 board in my 200dx....if it was that's hard to swallow when you buy a $5000 package. It was just out of warranty and a relatively low hour machine. I'll give em this, it was a first gen machine. Also, there are a bunch of Miller dealers around.....that comes with being the first ones to the show which they were. I am not here to badmouth Miller but there are other options. Paul at HTP is a good dude. Personally I do mostly aluminum repairs and ss/aluminum metal art on the side now but the invertig 221 is a very capable machine with as many programs as any other. In case you doubt the capabilities talk to dimesfabrication on instagram or google toxic fab. There are no inferior qualities and you get 10% more amps with the duty cycle to suit as well as basically a unit at half the price. Does HTP make their own welders? Not sure, probably not most of them but I do not care. They support them and have for 30 years. I got my HTP invertig 221 loaded for $2860 shipped. This included water cooler, 250 amp watercooled torch, 2 gallons of coolant, a spare consumables kit and everything to get up and running plus some free goodies like torch holder, stickers and 2 t shirts. I never received and freebies from miller with the exception of a replacement flexhead torch for my first gen diversion 165. That original torch was junk. I am not a big Lincoln fan because of how chinese they have been lately but the old dc600s and even stuff like a weldpak 180hd machines are hard to kill. Sorry, this is my opinion,. I am not forcing anything down anyone's throat but their are options that are reliable for people that can't afford to have a Dynasty sitting in their garage for when they get home from work. Dave
    A Zillion threads on this over the last 10 or so years...
    do some searching and be prepared for a LOT of reading ...
    you shall find your answer...
    The Dynasties are the finest TIG machines I have ever used and are continually evolving and improving..
    long term track record means a lot to those of us who depend on our tools..
    and yes... quality costs more.. not only the build quality and technology of the machine but the quality of the organization that stands behind it and support network as well
    whether it is worth it for you is a question that only you can answer
    quality tools can be a substantial investment..
    BTW... they are built in Appleton, Wisconson...
    Mar 2009
    Hazelwood Mo USA
    462
    I bought a Dynasty 200 DX in 2009, use it a few times a week, 350 hours on it and the only thing I had a problem with is the gas valve sticking, I removed it and lubed it up a bit and it works fine now again........
    mike sr
    Nov 2003
    3,572
    Jersey Welder
    You had a bad experience and that is a shame.. as you said.. your machine was a first gen version.. they have improved and evolved a lot since then..
    And if you search this board for Dynasty 200 failures.. you will find them to be relatively rare… how many thousands of Dyn 200’s have been produced since 2003 when they were introduced??
    so few failures.. yours being the most prominent…(on this board .. that I am aware of)
    I am not minimizing your loss.. I would be upset too.. but it is a relative rarity..
    My Dynasty 200DX(Blue Lightning) & 350DX Tigrunner … I bought new approx 2008 and they have performed flawlessly…
    And believe me... I thought long and hard before I invested in them… I had watched this board and others…(for a couple of years)... studied others experience and weighed whether all that extra cash outlay was worth my while..
    It was.. I would do it again.. The Miller Dynasty welders are the Finest TIG machines that I personally have ever used… And I have had the opportunity to own and use many different brands & types since I first started to learn TIG in 1968..
    Each of us decides how to spend our hard earned pennies…
    We will express our opinions and experiences… then the OP will decide what is the best decision for his circumstances…
    BTW... there has been enough evolution.. improvement change in the Dynasty 200DX during it's production life to warrant 29 versions of the manual and build style... this machine has been continually refined since introduction.....
    http://www.millerwelds.com/service/l...&submit=Search
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Mar 2013
    19
    Default 1 hr testing..
    I hear you 100% with the 1 hr testing cranked up, and electronic board failure expected then.
    i also here 'convince me' viewpoint as well. I'm NOT convinced!
    What I have noticed on the forums especially with the marketed ' heavy industrial' digital tig inverters is that the ones that have the knobs on the faceplate to adjust the welding menus and welding parameters are the ones that are quietly chugging along doing the job that they were designed to do with very few and minor repair complaints / issues (xmt 304 etc) while the same units or derivatives in the same family with the digital push button faceplate and same digital amp/ volt readouts are the ones that are failing at low amperages in use, usually in a home garage or hobbyist workshop, about 2000-3000 arc time hours out of 9999, error codes linking to which circuit boards are inoperative, and then being told by techs that parts are obsolete, buy a new one yada, yada, of this model yada, yada etc Windtunnel cooling yada yada for a heavy duty Industrial machine that is seeing light duty in a home garage. The experience is starting to sound like a repair trip with home appliance I.e. dryer, washer, fridge, stove, dishwasher yada, yada Not Good in my book for a 100% made in USA industrial welding machine.
    i saw about 10 years or so in a PVC / ceramic tile factory a White, shaped like a slotted bee hive( 2 ft high and diameter-no kidding), made in the USA, on small casters too, no ON light either, but one big
    ass on switch,
    welding machine with the plug in holes for the leads. (Just like my ol 35 millermatic) The owner of the factory saw me staring at it and came over. I asked him how old it was he smiled and replied maybe 1930-1920? It was heavy for its size and I asked if I could try welding with it. He smiled and said go ahead, it's the first welding unit they bought since the factory started. Well it went down to 20amps hole plug and the max amps was around 200 or so. Beautiful welding output smooth and totally quiet, no hum ,no fan, I actually put my ear to the round slats to hear the transformer, nada.
    he watched me weld on different settings and when I was finished I looked at him and asked him if he was interested in selling it.
    he looked at me with a smile and said Nope!
    and what brand was this jewel?
    SMITHS
    thats the longevity , reliability and welding satisfaction I look for in a heavy duty industrial welding unit made in the USA.
    if what they want to sell you today lasts 5-6 years in a garage setting for a heavy industrial welding unit and is 'circuit board unrepairable or obsolete" and they only repeat the same old mantra buy an upgrade -it's out of warranty... then what you purchased was a glorified expensive Christmas tree. Or disposable welder- like a cell phone now.
    think I'll pay him a visit soon and ask him again, maybe I might get lucky ( his son is an engineer but has no interest in learning welding lol)
    if I get lucky, i'll buy a quart of rust oleum safety blue and alternately paint the slats blue/white with the casters Red, then smile as I start welding with a smooth silent reliable welding unit that will outlast me and my grandchildren.
    And NO I'm not selling my mm35 either
    I'll use up the rest of the rust oleum blue on the wrapper, the paint and the rubber trigger hose , and the front castors seem to be the major wear parts on that model
    Analog rules long after when digital keeps on biting the dust!
    Apr 2010
    294
    The round "R2-D2" welder with the "pagoda" top is from the Smith Welding Equipment Corp. I never could figure out if it was related to the A.O. Smith welders, some of which were round, or may have some relation to "Smith's Inventions" which later became Smith's or just Smith - which makes O/A equipment. I suspect it was an entirely different company.
    I do see an occasional one for sale. There's been one on the Washington D.C. Craigslist for about 6 months.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
