    Jan 2014
    4
    Default Syncrowave 200 tig problem
    I am not a professional welder but Ive been tig welding for years. I had a Maxstar 90 machine that I started with in the late 90's. Welded both carbon and stainless with pretty good results right from the start. That machine broke 2 years ago so last year I bought a Syncrowave 200 to replace it. Wanted to start welding aluminum. When I first got the machine I used it to stick weld and was pretty happy with it. Then I got busy with work and didnt get to use it for 8 months. So I finally get it all set up to tig weld and am now having all kinds of trouble. The problem I am having is the diameter of the arc is large and appears to be coming from high up on the tungsten. The arc doesnt come off the point of the tungsten, it seems to come from the top of the taper. The tungsten also deteriorates rapidly. So I have looked for solutions and tried changing amperage, changing flow rate, changing tungsten, sharpening angles, polarity (just to see what would happen), stick out, torch angle and none of these things seem to change the quality of the arc. The arc just isnt concentrated off the tip of the tungsten. Any help or advice would be greatly appreciated. I dont know what else to try.
    Ukiah, Ca
    280
    AC or DC? What tungstens? Could be contaminated gas, or not enough.
    AutoArc 230 (MM 210)
    3035 spoolgun
    Spectrum 625
    Dialarc HF w/Coolmate 4
    Nov 2003
    3,572
    Quote Originally Posted by skl118 View Post
    More info and pics would give us a better idea as to what is going on.. and how to help you..
    also parameters and machine settings...
    meanwhile
    take a look here and see if anything looks familiar..
    http://www.millerwelds.com/resources...-guide-graphic
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jan 2014
    4
    Thanks for the replies. I am running DCEN, on 1/8 inch carbon and stainless, I have tried 1/16 and 3/32 Ceriated and Thoriated tungsten, and I have varied the amps below, through, and above the ranges recommended in the owners manual for the size of tungsten (50-160 and 130-250). When I make these changes the arc never becomes a nice sharp arc off the tip of the tungsten.
    I looked at the page H80N suggested and the only weld that looks like mine is the sugaring on the backside of the stainless steel. I've welded this stainless in the past without sugaring and no back purge so I know that I should be able to do it. If I reduce amps as that page suggests then I don't get a good puddle.
    I will take some pictures hopefully tonight and post them. Thanks for the help.
    Nov 2003
    3,572
    Question
    You are not by any chance using "Bargain" chinese collets and holders off of fleabay.. are you??
    there have been a lot of instances of them restricting gas flow or creating turbulence that wreaks havoc on weld beads...
    poor quality control, soft copper, off dimension... these things can look ok to the eyeball but be bad news..
    Here is just one example..
    http://www.millerwelds.com/resources...hlight=collets
    BTW...
    have also heard of some problems with imported tungstens that may be mismarked or of questionable purity or alloy......
    My Blue Stuff:
    Aug 2008
    Orange, TX
    1,216
    Check your shielding gas and make sure it's 100% argon.
    Did you just change bottles?
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Jan 2014
    4
    The torch and all its parts are Weldcraft and came with the welder. It is a new bottle and its labeled argon. I can hear and feel gas coming out at 20 cfh but i wasnt sure if it was flowing enough so i cranked it up to 30 and 40 cfh and there was no change in the arc. I havent done a leak check to see if the gas is sucking air somewhere so tomorrow I am going to hit it with soapy water and check for bubbles.
    Nov 2003
    3,572
    a bad o-ring or cracked back cap will allow it to suck air and mess up your beads...
    17 series torch..??
    My Blue Stuff:
    Jan 2014
    4
    It was bad gas. I swapped out a borrowed bottle and ran the top bead in the attached picture. I noticed an immediate improvement. Then switched back to the bad bottle and ran the bottom bead without changing any other settings and it was right back to garbage. Thanks for the replies and the help.
