Results 11 to 12 of 12
    Apr 2012
    Western Pa.
    335
    Default welding magnetized drill pipe
    I keep a 5lb. Box of Lincoln 7018-AC Rods just in case I run into such a problem. They run nice for A/C but as most, prefer D/C.
    Oct 2012
    Neosho Mo
    79
    I'm assuming the pipe you're using is for fence or something like that, and if you have gaps try beating the flux of 1of them 6011s and lay it down in the gap and weld over top of it. Turn your machine up a fraction because of the extra filler metal. Do this if your building fence or something similar to that. If you are building trusses or anything of that nature you need to go ahead and fill it
