Results 1 to 10 of 11
    Jan 2014
    Question Grinding finish welds ,good or bad
    What's wrong with this pic take a look tell me if this is a pass . 95% of the welds on injector crash cage are like this can this be a problemDSC05770 (640x360).jpgDSC05768 (640x360).jpg
    4,477
    A lot of welds are ground and polished but this isn't the case, something is wrong here.
    Jan 2014
    17
    Hard to tell with them ground like that. But from my experience when someone grinds a weld half way down it's because they are trying to hide an ugly bead.
    Oct 2009
    306
    If you grind your welds you are a grinder not a weldor. That's all I have to say about that.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Jun 2009
    greenfield new hampshire
    889
    about grinding welds, i always grind my welds, always, for a paying job, rarely for myself. some gravy, flat work usually can skip the grinding, but if i am building a complex frame where people will be using it, hands on, i like to clean up the welds, removing any spatter or sharpies, that does not make me a grinder, it does make me a smart business owner,if i put a finished product out the oor with some spatter on it and some one gets cut, i can get sued, this is america,
    Wa
    644
    There's a difference between removing spatter and grinding half the bead down.
    3,953
    Quote Originally Posted by kevin View Post
    this is america,
    Where i work every weld has to be ground or polished off. I don't like the idea since good welds now look bad but that's what the place wants...Bob
    Jun 2009
    889
    your right cgotto6, i took a better look at the pics, wtf
    May 2012
    215
    Default good or bad welds
    well I didn't see any porosity that is a plus but that is a fine example of mechanical undercut and a bit of L.O.T
    Oct 2009
    306
    Hey Kevin
    Always clean spatter and any sharp edges that's just doing a job right. Unless specified don't grind your welds.
Tags for this Thread
