    Oct 2013
    28
    Default stiff cables on plasma cutter
    Hi I got my miller375 xtreme about 2 years ago and the cables on it were Reilly stiff, I thought that they would loosen up after some use but they didn't.it has the ICE tourch on it,I know this sounds dumb but it is very annoying all help would be appreciated thanks.
    Rosetown, SK.
    520
    Have 2050 which we bought new torch assembly about 2 years ago. Same problem, very frustrating. Newer series have more flexible components.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    1,928
    My 875 torch cable is very stiff also & very annoying. That is the only complaint I have though.
    Apr 2012
    Western Pa.
    334
    Hypertherm 85, same, my only real complaint.
    I have leather covers on both leads which makes even a little worse.
    not near you
    148
    Buy a Thermal Dynamics plaz cutter........Ive had a miller, and a lincoln and the Thermal Dynamics blows them away.....stiff torch is not an issue...even the 80 amp model doesn't have too stiff a lead... Just my opinion.....YMMV....
    Oct 2013
    28
    Ok thanks
