Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Jan 2014
    9
    Default hi new here trying to setup a bobcat 250 so i can weld aluminum
    hi new here trying to setup a bobcat 250 so i can weld aluminum i am a code welder i now a bobcat is not the best from welding aluminum its not a HF welder but I'm shore there is manny options what I'm going to be doing is alum- sheet metal the very thickest would be 1/4 I'm going to build aluminum john boats gas tanks things like that after i build and sale some i will be buying a new welder one that is a HF
    Jan 2014
    You can buy a A/C HF adaptor unit and use your bobcat.No bigs.
    8,225
    Well, why tig, run a spoolgun off your CV setting on your machine, so a WC-115 with contactor, Miller 30A, a bottle of Argon and off you go. Crazy simple and about 100 times faster than tig.
    Dec 2010
    Andover, Ohio
    144
    Welcome to the forum Jason.
    Jan 2014
    9
    Quote Originally Posted by Seabass108 View Post
    seams like someone told me about that before but this is not remote hookup right the only way to adjust the heat is to stop and adjust it at the welder right?
    Lake of the Ozarks MO
    3,594
    Exactly
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jan 2014
    9
    Default with a mig what's my option
    with a mig what's my option I've used a miller 30 spool gun and can't really complain it dose the job but there kinda pricey is it the best bang for the buck
    Jan 2014
    9
    Default how about the WC-2
    i found a used WC-2 controller for about 200$ will it work with a bobcat 250
    Aug 2008
    Orange, TX
    1,216
    It could but you'd need a Spoolmatic 2 spool gun to go with it and you still wouldn't have a contactor.
    The WC-2 was designed for use with power sources equipped with a contactor and as you know the Bobcat doesn't.
    I'd suggest going with cruizer's recommendation.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Jan 2014
    9
    Default what about spool gun + controller
    what about spool gun + controller is the miller spoolmatic 30 or 15 with a WC115a controller my only good option its a $2000 one at that…is there any other controller that will work
